1 - 8 of 8 Posts
Anybody every install the SRT intake and have hood clearance probs?
Everything went together pretty smoothly.. but when i close the hood.. it gets hung up.
Anybody got any good close up pics of their install so i can make sure everything is good?
The problem is one spot on top of the SRT heat shield rubs the insulation under the hood. Get a file and whack off some material. I didnt notice it at first so now I have a hole in the insulation.
hey thanks im waithing for my SRT intake so before i install it ill take some material of the top thanks!
you shouldn't need to shave anything. I installed my SRT intake with no clearance problems. Check to see if you have proper alignment or loose bolts.
not all car and intakes/heatshields are exactly alike.
Well there are only two bolts that hold it down to the chasis.. and i had to flex the heat plate a little bit to get the bolt holes to line up.
I'm also gonna say that not every car / intake is machined the same way.
Thanks guys, I think im gonna get a ruler out.. some tin snips and maybe take a 1/4 inch of the topof the heat sheild
if the hood doesnt close, the heatshield is not in properly. I wouldnt cut it b/c the problem is with the install, not the product. Just double check everything.
1 - 8 of 8 Posts
