I was wondering will a Apexi SAFC II work with the ecu from the srt intake? Didnt know if they were compatible or not.
Podiatrist
they do the same thing. It's like putting on 2 right shoes.
Mr. Negative
Re: hey
yes, but you'll need to tune it properly first. unless you are getting a header I wouldn't worry about it. The ecu that srt is a fitted shoe whereas the SAFC is a shoe that still doesn't have laces and might need a insole to fit right(to continue sophie's analogy).
sidetracked3 said:
So could I take off the ecu and just use the apexi afc?
Not Officially Back
Re: hey
and in this case a fitted shoe is ok because the guy who made it knows that all the feet are pretty much the same size.
did you guys know that the srt r-ecu has 2 presets 1. regular intake mode 2. intake/header mode
to continue the analogy the srt ecu is kinda a one-size fits all shoe it changes sizes once your feet gets bigger, in this case the more mods you add to your car
someone told me on the forums, i was skeptical but i emailed and marken told me it was true
