I still have a few months probably before I need to clean/change my intake filter. Are they any quick easy ways to clean ur filter or do I have to buy a brand new one?
if your lazy, buy a new filter.
buy K&N cleaning kit from pep boys/autozone or whatever.
you will basically rinse the filter first to get any loose debris off and such.
you will then use the k&n cleaner (soap) and put it on the filter and let it sit for awhile.
you will then rinse the cleaner solution off and any other dirt and such that is stuck in your filter.
let it air dry.
use the k&n oil and oil the filter.
tip for removing dirt: use carbonate water and put it in a bucket while adding oxyclean or the k&n cleaner solution.
Thanx a lot :)
