I'm trying to get help for installing the SRT ECU...
I did some searches on the forums..found a link to a srt.zip which I assume was a PDF File, cant find it anymore, link is dead.
And next questions, is there a harness that you can use as to not cut wires on the ECU?
If these questions have been answered before, what keywords did you use?
I tried +SRT +install +guide +ECU no dice......
Thanks for any help provided.
did you buy it used and it didnt come w/ instructions?
no harnesses you have to splice/cut the wires
Podiatrist
you only cut 1 wire. the rest you splice.
Do you have to soder the wires or can you use self tapers? I know it says soder, but would it make much of a difference?
Podiatrist
Just be safe and solder it.
There are no harnesses for it, you must cut and tap. Please do not use any type of crimps, always solder. The handful of people that have had problems were with bad crimp connections, once soldered it was fixed.
