Hi all,
I installed my L-tuned sways sometime in '02. Upon first install I greased the HELL outta the bushings and yet I still heard a little bit of creaking at parking lot speeds when turning the wheel all the way or entering a driveway, but it was minor. Now I'm hearing major creakage in driveways, turning at slow speeds, speed bumps, etc. It's kind of embarrassing cruising in a new Lex with all of these squeaks going on. One Lex mechanic told me I might not have matched up the notches in the front shocks (stock) where they mount at the top. ?? I've had someone turn the wheel in a driveway while I lay under the wheel well but I can't definitively identify the source of the noise.
Anyone else have this problem and can recommend a specific type of grease to use on the bushings, if that's my issue? I may just have to take the shocks off again and check their fit. :-?
