squeaking noise when sunroof is tilted
621 Views 2 Replies 3 Participants Last post by  N1
I am getting squeaking noise from the sunroof switch area when the sunroof is in tilt position ONLY. I just push up and down on the headliner around the sunroof switch area to produce it. Anyone else has a similar problem?
See less See more
i have the same problems...oh well..
See less See more
I've had this noise, sounds like plastic pieces grinding, and only happens when weather is cold. Went to dealer to recreate problem, no noise. Not happening anymore. will have to wait till it happens again.
