today i was washing my car, and i sprayed off the engine. Not the whle thing just down by the headers and catlyst. But later on tonight i go and try to move my car into the garage, the car starts adn revs up like normally, but the all the sudden the car sputters and it tries to catch itsself, but the motor dies. I try to restart it and it does the same thing. SO i try to start it and give it a little throttle, it run, but then it just dies? Does anybody know waht is happening????
Podiatrist
why were you spraying water into your engine?
Open the hood and open the hood and hope it dries. Open all the available boxes including the fuse box by the battery and other shit. Hope it dries. Disconnect your neg terminal.
and then...never do that again.
It should be fine when it dries. Hope you live in a warm place.
mud had sluhng up onto the catlyst and up into the motor. I never got the fuse box or any otehr box wet. waht if you get those sensors wet that plug into the catlyst??? WOuld taht have soemthing to do with it? This is relly starting to scare me because it sounds so bad on the motor
