1 - 9 of 9 Posts
so, is it true that everybody that install there spring gets those warning auto-headlight or you only get that warning from mechanics not installing shocks and springs incorrectly???
any good and reputable shops in socal that i don't have to worry about this warning light?? TIA
Threadlocker
the problem is that some mechanics loosen the sensor bolt even though they don't need to. then they put it back in the wrong position, which happens to be outside of the headlight adjustment range, which in turn gives us the warning light.
the sensor is easy to readjust, but if you don't want them to mess with it you should warn them ahead of time.
personally i got my install done at thewheelsupply. the mechanic knows what he's doing and he's done a few IS's
btw if you call them ask for sander..
alright....thanks
btw, you got a number for that place?
another good shop is:
westend alignment
ask for darin, (310) 808-9233
didn't even need to touch the sensor
great job - several others have had great service from him
very busy though - need to schedule appointment
does a lot of racers
hellomoto said:
man, i just got my car dropped this afternoon and the auto-headlight warning came up :x . is there anything that i can do to fix that or i have to bring it back to the shop? :eek:
02 msm e-shift
check the sticky on top...
btw, westend alignment cost $350 for install and alignment!!! :eek:
auto-level lights
ya...its a lever at the left rear of the car adjacent to the left rear wheel...check that and adjust it to the center...you should be fine...
1 - 9 of 9 Posts
