1 - 2 of 2 Posts
OK, I'm sure that this is an idiotic question, but let it be known that I did check the stickies in the forum before asking, and doing a search was fruitless!!! 8)
What exactly is the difference between springs and coilovers? I'm assuming that the coilovers incorporate some other function because they're so much more expensive. If I were looking to do a simple 1.5" drop, would a set of Teins accomplish everything that I was looking to do? Would I need to add aftermarket shocks or would stock be fine?
Thanks in advance....
Threadlocker
coilovers allow for adjustable heights. if you just want to drop it to a certain height and leave it at that, then just a set of springs would do just fine.
1 - 2 of 2 Posts
