1 - 20 of 63 Posts
· Registered
Iv had many is300's and have been on here a while. Both my previous is300's were turbo one on a stock motor the other on a gte bottom end. Three years ago I got out of the game to buy a suv (Needed one for the house and towing) Since my exit things have changed and in October I pulled the trigger on a ISF. The car is near mint with 33k on the dash. Being my drive is so crappy to work I didnt want to drive it every day, so my IS300 daily search began. Upon looking I came across the unicorn which is the Sportcross. I have only seen one on the road ever and fell inlove. I went to look at the car and using the lexus app found the car was very well maintained. The exterior and interior was new perfect so I picked it up. I drove from chicago to detroit for it and it was worth it in my opinion.
Here is the car the day I bought it. Dont mind the ugly wheels,floor mats and nasty red calipers.
Finally home
I have a lot headed this cars way and will post as I go
· Registered
Welcome to the site, didn't know there was a Lexus app. What plans do you have for this car as a daily?
· Registered
Discussion Starter · #3 · (Edited)
Thanks curran been here since 2007 love the site and everyone willing to help on here
I plan on building the block I have sitting in my garage. I have brand new gte pistons and rods up in my attic from my old days i never used.
Heres my old cars
01 stock internals on a Turbonetics kit with kaminari full lip kit
01 gte internals,head gasket and custom kit everything i made with the exception of the turbo manifold ran on a f10x and did close to 450whp
· Registered
Discussion Starter · #4 · (Edited)
Today after work I did some cosmetic items along with some maintenance items.
I got emusa coilovers but they failed in 2 weeks!! See page 3 for the suspension update. When I took apart the front you can clearly see that the lower ball joints, front sway bar bushings, sway bar links and even the strut mounts were replaced and brand new. The seller told me this was done but you never know if its smoke or not. I replaced the rear sway bar bushings and links as well.
Also did a paint correction. I wet sanded the some problem areas used a microfiber cutting pad finished with a nice finishing waz and i gotta say im thrilled with the results. It looks new and the paint has amazing depth.
After all that I did a brake flush, oil change, spark plugs and a air filter which was nasty. Plasti diped the wheels and got rid of those ugly red calipers.
Pretty happy with the results. Ill post some day time photos as well
· Registered
Discussion Starter · #5 · (Edited)
On my test drive of the suspension I stopped at my storage unit to grab the block from my old IS. Little more rusted since the last time i say it but once my machine shop gets it she will be as good as new.
I have some gte pistons and some brand new gte rods in my garage attic. So hopefully on Saturday i will be dropping the motor off to get going. Im gonna use the Apex Engineering who is the same guy who does all of the machine work for Sound Performance not to mention a insane amount of 2j's all over.
Ill be doing the following:
GTE Pistons with new rings
GTE Rods
Clevite Bearings and Thrust Washers
GTE or GE head gasket haven't decided yet
OEM Water Pump/Timing Belt Kit
New OEM Oil Pump
All OEM o-rings and gaskets along with sealant
Head will be checked and new valves,springs,the whole nine will be all replaced and new
Im gonna go for a safe every day 7-8 psi of boost on a Emanage Ultimate as well
· Registered
Discussion Starter · #6 · (Edited)
Just spoke with XS Power, Ill be doing their full turbo kit for this build along with a emanage ultimate and injectors (Not sure on the cc yet)
Ill be updating this build as I go and will put plenty of the photos up of the turbo kit for others who are on the fence. The goal here is a nice reliable boosted is300 that i can drive every day anywhere
· Registered
Just spoke with XS Power, Ill be doing their full turbo kit for this build along with a manage ultimate and injectors (Not sure on the cc yet)
Amazon.com: XS-Power T3 GT35 Turbo Charger Anti-Surge 500+ HP + Oil Fitting Complete Accessories Kit: Automotive
Subscribed. cant wait!
· Registered
Update: Dropped off my block and head at Apex Engineering in Bensenville IL yesterday. This guy is the 2J King around here everyone whos doing a build used him. He had 4 2J blocks a couple gte blocks and one 1J even. Should hear from him in a week of so to see hot to block and crank checks out.
Here's whats going in the block
GTE Pistons ( Newish they were out of a brand new assembled short block)
GTE Rods (New)
New Rings
Clevite Racing 77 bearings and thrust washers
As for the head
New springs
New Valves
New Valve Seals
Everything is going to be gone through and checked to make sure things such as engine deck,head deck,cam lobes, etc is in proper specs if something is off it will be replaced with new.
Once the engine is built it will be checked for squish and quench from that point ill decide to use the ge or the gte head gasket.
· Registered
GTE Rods (New)
New Rings
As for the head
New springs
New Valves
New Valve Seals
Apex Engineering huh? I never heard of them. I was planning to go to Sound Performance but since they have him do the work as well I might contact him.
· Registered
Sound performance uses apex to do the machining on their blocks. If you can't put the motor together years elf then yeah use sp but apex puts the bottom end to make it a short block
Call apex as talk to bill tell him nick referred you and he will help you out. I have done a lot of blocks with him.
· Registered
Gotcha. Im planning to go gte internals as well. :grin: Thank you, I'll definitely keep him in mind. What made you go xspower and not piecing together a kit anymore? I've read so many reviews saying the quality is basically the same as a generic off ebay stuff
· Registered
Discussion Starter · #13 · (Edited)
Iv built my own kit before and I just don't feel its worth the savings.The amount of time spent on intercooler piping and fabrication isn't worth it. Id rather but a "ebay kit" keep the manifold which is a copy of the Turboeast original, keep intercooler piping and upgrade the turbo, wastegate and bov. Still save over srt and other.
· Registered
Actually I'm not 100% on xs power yet. Iv built my own kit before and I just don't feel its worth the savings.The amount of time spent on intercooler piping and fabrication isn't worth it. Id rather but a "ebay kit" keep the manifold which is a copy of the Turboeast original, keep intercooler piping and upgrade the turbo, wastegate and bov. Still save over srt and other.
I see. I know a few had issues with the welds cracking but I think they have a newer version manifold out now. I wouldn't mind the srt kit but the fact that MO doesn't responds or sends out anything is horrific.
· Registered
Discussion Starter · #16 ·
Iv had the xs power manifold on my white car thats in this post.
I ran it for 10k had a lot of abuse and never had a problem with it or the downpipe
SRT is a joke i wouldn't order anything from them. Id rather buy a xs kit and down the road should it fail upgrade the turbo,bov, and wastegate. I don't think I'll have to with the amount of boost I'll be running thought.
It all depends on how well you build the car at the end of the day, proper fuel system and without a doubt the management.
These kits get a bad rap because people throw a kit on a car and go rip boost. YOU CANT DO THAT!
· Registered
I agree ive been running an XS Power manifold for about 6k miles now with no issues. Made 740whp with it and plan to make 1000whp with it next. I use use their downpipe but that will have the be changed just to reach my HP goals only.
· Registered
I completely agree most people don't understand management is everything. A engine needs fuel, air, and spark, and without the proper balance, bye bye motor. Most people give XSPOWER a bad rap because they buy it for the price and don't do any tuning, and end up blowing their motor. Ive been boosting for 1 year and about 6 months with their kit love it.
· Registered
Discussion Starter · #19 · (Edited)
Turbo kit is here!!!
I ordered the kit and it took just 4 days to receive it. Today i got it and I have to say I'm impressed.
First lets talk about the manifold. Every single weld is spot on each exhaust port is extremely clean, the T4 mount and collector welds are better than my last SRT manifold and its just freaking beautiful to look at.
The downpipe is the same way. It has 3 o2 bungs which is the same as most so you can support your B1S1 B2S1 and wideband sensor. Again welds are perfect and its heavy duty just like the manifold.It features a slight kick to better clear the firewall as well. My previous kit years ago from a different company was always close and I didn't much like that. The pipe is 3" features a v-band for the turbo and 2 bolt to complete the rest of the system.
The best part which I though would have needed ordering is it came with all of the necessary feed lines,fittings,vacuum lines,gaskets,hardwear,manifold and turbo studs, and even the oil feed adapter for the block.
The BOV is a RS style to the Tial style. I used to have a RS on old kit and I gotta say this looks the exact same. Quality is on point and love the v-band. Wastegate is a 4 bolt HKS style and seems good quality as well.
Turbo is a T4 styled after a Garrett GT35. Its oil feed only and has a ar of Compressor wheel (Front) is a AR of.60 and the exhaust side is a AR of .84. Full spool should be right at 3k. I also opted for the turbo blanket which is very nice.
The intercooler kit couldn't be better. The intercooler is nice and big but not so big that its gonna creat pressure drop. The hot side piping is 2.5 and the cold side is 2.75 which is the same as the stock intake tube so it will be perfect for the MAF readings since nothing is changing.
All in all Im impressed.
If you guys need anything or have questions let me know ill try to help. I hope this post helps others that want to boost but not go crazy in power and price. I plan to roll 8-10psi daily which this will have no problem at all doing
Fuel system and management is all thats left when you buy this kit.
Tons of you are asking me where to get the kit or contact someone. I dont sell the kit i just reviewed it for people to help. For info email this guy
[email protected]
· Registered
Ok so its here!! I actually got to speak with the owner of XS Power and he told me they are rolling out a new design for 2016 and he would let me be the first to receive it.
The BOV is all new changing from the RS style to the Tial style. I used to have a Tial on old kit and I gotta say this looks the exact same. Quality is on point and love the v-band. Wastegate is a 4 bolt HKS style and seems good quality as well.
Turbo is a T4 styled after a Garrett GT35. Its oil feed only and has a ar of .60 .84. Full spool should be right at 3k. I also opted for the turbo blanket which is very nice.
:jawDrop: wow, I'm impressed. looks REAL good. can't wait to see it on.
1 - 20 of 63 Posts
