1 - 9 of 9 Posts
are you referring to the blitz dynometer speed sensor wire install? if so, i was successfully able to do it after someone emailed me a pic of what needed to be tapped. i believe is300gte has the pics. if i still have it i'll post it.
pics are all red x's
to install speed sensor is easy....unbolt from the control arm/hub.....
work your way from the control arm to the other end of the wire and unbolt all connections.....until you come to where it unplugs....
crappy explanation...but easy task
you need to remove the wheel when you do it....and you might have to unbolt the rubber sheild for the wheelwell
buy lithium grease for the new sensor...so water/brake dust doesn't get in
good luck...it's easier then i make it sound
1 - 9 of 9 Posts
