I want to know if my speakers will fit in the factory spot. The woofer (which I think it will from readin posts) mounting depth=2.80, mounting diameter = 5.75, and overall 6.75 inches. Now the tweeter , depth is .50 inches, mounting diameter is 1.40inches and overall diameter is 2.05inches.
The tweeter is not going to fit.
I had problems with a 1" tweeter. The MBQuart 1" tweeter, that is. Not sure what its exact measurements are, but it was close. I had to reform the mesh to get it to fit properly.
I doubt the speaker is going to fit, either. Not sure what max depth is, but you're going to have to do some custom fabricating. While custom fab'ing is already needed, you're going to have to go the extra mile.
What speaker set is this?
Useless
The tweeter would appear a no go in factory location without custom work.
The mids will most likely fit as the depth is fine. You need to fab a baffle mount anyways, so I dont see why one with a slightly larger mount hole would really matter.
I was told that the tweeter can pop out of its housing.
This is what I was told "But if you pop the 650 tweet out of the housing you can fit it anywhere you've got .25" to fit it."
Does that statement help at all???
