Does anyone know how to get the speaker covers off on the 4 doors???? Is it an easy pop off of them like some cars, or do you have to remove some of the door stuff?? I don't want to break anything by forcing stuff off. HELP!!!
the door is held on by clips...I forgot which way you have to pull it but there are clips surrounding the door...the speaker cover is attached to the door...so if you get the door off...the speaker cover comes off with it. Not quite sure if you can take it off by itself..might scratch something in the process.
You have to unscrew two screws to get the door panels off, one is in that little holder on the door and the other is hidden by the door locks. Unscrew both of those and then you can just pull off the panels and when your done they just click back in.
