dskang100 said:
Has anyone tried this so far? I think i'm gonna do it pretty soon since i'm adding a computer to my car (props to Greekgod for many cool ideas) I don't wanna use an FM Modulator either... also i don't have a stock nav i bought a farenheit monitor and the housing..
I tried doing it and it works for all practical purposes, but I also did some experimenting on my own while I was doing it. SophieSleeps, maybe you can offer some insight to what I found:
According to your AUX input instructions. here is what you said
You are cutting wires:
(these are for the grounds)
Red pin 19
Yellow pin 15
Brown or Black pin 18
(these are for the signal +)
white pin 9
green pin 8
My own experimenting also came up with similar results:
Red and White are for the LEFT channel
Green and Black are for the RIGHT channel
However, I did not touch the Yellow wire at all, I'm guessing that is just an extra ground?
So anyway, as opposed to your instructions, I only cut 4 wires, Red, White, Green, and Black. Following this, if I ONLY connect back the Red OR White wire, I get SOME sound out of the LEFT channel. However if I connect the Red AND White wires, I get MORE sound out of the LEFT channel. The same happens with the Green and Black wires with the RIGHT channel.
This has left me to assume that even though the Red and White are supposed to a pair and the Green abd Black are supposed to be a pair, each pair doesn't seem to consist of one (+) and one (-). Seems like some sort of differential signal going through each pair of wires (all you electrical engineers out there, correct me if I don't sound right).
This also explains why when a normal (+) (-) source like my MP3 player is connected in, the sound level is low, like when I only connected one of the pairs of wires for each channel.
Does everyone follow me? SophieSleeps, I ain't trying to knock your instructions because like I said, for all practical purposes it works just fine, however I'm trying to fill in some of the blanks I found while doing this modification to my IS300.
If anyone else has tried this and found something similar and can expand on what I found, please post your findings!
