1 - 15 of 15 Posts
· Registered
Originally posted by webguyIS:
Very nice job, did you use the Replace Color feature?
No, you lose all the reflections in the hood and such. I actually copied the pic into a new layer, used the image/adjust/colors to make big adjustments then image/adjust/curves to tweak. Then just erase the parts around the car you don't want and the original layer shows (so grass and house and wheels are perfect. Voila! Thanks for the props!
· Registered
the blue is really nice, hope the factory dark blue mica looks as nice.
· Registered
Originally posted by scoot557:
thats awesome - good job. where can i pick m eup that blue color??
That is actually what I prey the new blue will look like cause I am getting a 2002. I took a sample from the Altezza and then worked it. It is darker than the SBM which is supposed to be the way the new blue will go. Keep your fingers crossed!!
· Moderator
[qb]thats awesome - good job. where can i pick m eup that blue color??
That is actually what I prey the new blue will look like cause I am getting a 2002. I took a sample from the Altezza and then worked it. It is darker than the SBM which is supposed to be the way the new blue will go. Keep your fingers crossed!![/QB]
OOOOH, sometimes I can't resist...Don't take it personally, but while you may feel like PREYing on other vehicles with your new blue baby, I PRAY you would be reckless when you do it!
1 - 15 of 15 Posts
