So, you’re driver side front door speakers are out?
And your car had sat nav, but you’ve unplugged it?
That’s your problem right there ☝
The audio signal for the driver side front door speaker passes the dvd sat nav unit, and if you disconnect it, the speakers go out. Probably because of the sat nav voice.
It took me some time to figure this out, and I thought I’ll share it with you here, in case someone has the same issue.
If you don’t have the sat nav dvd unit available, you can bypass by doing this (picture). 👍
