Anyone who owns an AEM EMS and doesn't want to spend over $500 on a gauge pod and three gauges that you're stuck with? Want a display that can be programmed to display up to 16 parameters? Then this display is for you!
This is a hand-built, high-quality display designed to be integrated with the AEM stand-alone Engine Management System (EMS). Popular among many Supra owners, this is a no-frills, all pure function device which allows the digital display of anything the AEM can monitor. It is very customizable and can display multiple parameters at once. The best feature is a built in warning light which activates at any user programmed setting!
This was purchased about six months ago from Gauge-Tech Home Page (please check-out the URL for more info on the capabilities of this gauge).
Considered new because it was never mounted and put into operation.
The original purchase price was $375 (not including shipping).
I will sell this item for $275 obo including shipping (inside CONUS).
From the GAUGE-TECH.com website:
Features
Works with any AEM EMS equipped vehicle
The digital dash will work in any vehicle as long as it is equipped with an AEM engine management system. Firmware is available for EMS software versions 0.89, 0.94, 1.03, 1.11, 1.19.
EL Backlit LCD display
The digital dash uses an EL backlit LCD for nighttime viewing.
Plug & Play functionality
The digital dash comes complete with a cigarette lighter adapter and serial cable. To setup the unit simply attach the serial cable to the EMS's serial cable, plug in the cigarette lighter adapter and you're ready to go!
Monitor any engine parameters in real time
The digital dash can show up to 16 different parameters on the display in real time. Choose from all of parameters available to monitor (AFR, AFR target, knock, Ignition timing, coolant temp, intake air temp, battery voltage, injectory duty, the list goes on and on) Update rates vary, expect anywhere from 20 to 40 updates per second!
Full featured peak hold, warning gauge functionality on all parameters
The peak value for each parameter being monitored is automatically stored, and can be recalled at the push of a button. Warning levels for all parameters can also be set so that if something is going wrong you'll know instantly. This functionality alone allows the digital dash to replace 16 full featured individual gauges!
Graphing / Configurable display units
Graph mode or Unit mode can be selected for each parameter. Some of the available units are. Celsius/Fahrenheit, kPa/PSI, AFR/lambda, mph/kph, etc.
Super bright warning LED
A super bright LED is built into every digital dash display. This LED is activated by settings you are able to specify. Whether it be a lean AFR condition, over boost or engine knock, the digital dash will warn you.
MPG, Horsepower & Torque calculations
Instantaneous MPG, wheel horsepower and wheel torque can be viewed on the dash, just like other parameters are.
User upgradeable via free downloadable firmware
The digital dash firmware is continually evolving and upgrades are always available for free. User software is supplied which allows you to upgrade your unit without having to send it back to us.
Intuitive menu navigation
A rotary selector and 4 buttons on the face of the digital dash, allow for quick and easy setup, and configuration of the unit.
Machined aluminum display housing
The digital dash display is made out of high quality CNC machined aluminum.
Features
