1 - 20 of 86 Posts
Shitty gas available in the US..my car has never seen or operated on anything less than 98 octane. 95% of the time the car has 104 octane from the pump running thru her. The best i can get here is 94 octane piss water. Will an octane booster bring the rating up 4 points to 98? I know it wont bring it up to 104...what am i supposed to do? any HELPFUL suggestions are very apperciated
Its not always safe to run octane booster all the time ( I would not think it would be)
You are going to get pinging, and knocking :lol:
So unless you can do some tuning its going to be hurting
Penetration Specialist
Why do you NEED such a high octane? Does the altezza require more than 93? There are a few gas station down here that sell over 100 octance unleaded for about $5/gallon (well probably > than $5 now.)
same question I have? Why does the Altezza need more than 93 octane?
you are wasting your money runnign that high of an octane, youre just bruning it off. keep the high octane stuff for the track
Discussion Starter #8
the gas off base in japan is all pretty high octane. when i got gas off base it was always at least 98 and if my pockets were deep enough i would get super which is 104. about 6 bucks a gallon.
tsop i will be back to actually drive the car in nove/dec time frame
i know where that gas station on rt46 is..just didnt know they sold high octane..they dont have anything higher than 104 tho? thanks for the suggestions peeps. much apperciated :)
on the dynbo i made 26ps more to the wheels running 104 btw. it makes a difference. its like crack for your car :lol:
yeah, but IMO, a true street car runs on pump gas, not race gas
im sure many people on here could produce amazign numbers on race gas, but that kinda takes the fun out of it
6 dollars a GALLON... BAHHAHAHAHAHAHAH good luck with that waste of money
:lol:
Tarik: what are you going to be doing post military? Job wise?
Don't forget that different parts of the world use different Octane ratings. So a 94 in one place for example might be a 104 in another country. So make sure you are comparing apples to apples.
who the hell would spend upwards a 100 dollars to fill up their gas tank for daily driving. Tarik, you are a one of a kind idiot. You have an all motor ALTEZZAA BRO... stick to the pump gas you goon...
6 dollars a GALLON! BAHAHAHHAHAHAHAHAHAHAHAHAHAHHA
Turbo Altezza now :lol:
tarik in japan they do not use the RM/2 method we use here in the US, which susequently, produces lower octane numbers. The equivelent of our 93 is approximatley 97.886 or round it up to 98...FYI I forget the exact name of the formula used. I think i have the link to the conversion website let me look... a similar comparrison would be in the electronics world, of RMS to peak.
edit: I get 110 leaded for the track at mobil down here.. 599 a gallon.. butonly for the track... I know that I am hard on the car at the track and the lead in the gas acts as top cylinder lube.. also helpe keep enigne temps down..
This is besides the point. There is nothing special about his car... its All Motor. Premium at a gas station just like any other IS300 owner would be enough. lol... I am not one to keep poking but i mean who in the right mind would spend 6 dollars a gallon to drive around in the city....
6 DOLLARS A GALLON (I can't stop laughing) BAHAHHAHAHAHAHAHAHHAHAHA
Tarik you are one in a million man.
Discussion Starter #17
didnt you read what IMPRIMIS wrote? the caris turbo now tuff guy
besides the car was tuned on 100+ octane. all my setting on my car are all done with 100+ gas.
Discussion Starter #18
hmmm... so that means i could get away with using 98 at the pump in NJ and be OK?
another problem: the battery posts on US batteries is alot taller than the Japanese ones...it should still fit tho correct?
i honestly dont see the point in using race gas unless you are trying to reach some crazy dyno numbers, or racing on a track. daily driving or going to a meet is just a waste of money in my opinion...if you could burn money like its nothing, then why did you get an altezza?
as I said, the Sunoco in Ledgewood on rt 46 has 100 octane unleaded at the pump ;)
1 - 20 of 86 Posts
