1 - 2 of 2 Posts
what does the e-shift do? does it go from 1-2-3-4-5 gears or L-3-4-5. i saw a digital display of the "m" mode with a 1 in the box has anyone really seen it work correctly
I have. When you shift into "M" mode, the area on the left side of the dashboard turns on and 2nd gear shows (unless you're moving fast, in which case it stays in the gear you're currently in). The digital gear display never shows 1 because you can't shift into first gear, nor does it show it when you're completely stopped. When you push the "Up" button, the gear shifts up and when you push "Down" the gear shifts down. It's the simple, and it works really well if you know what you're doing, hehe.
Hope that answered your question
1 - 2 of 2 Posts
