Any luck with these things yet?
Funny you ask, I just got home just now. I yesterday I drove from LA to Redding. Obviously no snow but the rain was pouring and I think its funny how much Californians complain about the rain.
Today I drove from Redding to Seattle and had to pass the Yerika to Ashland area that required chains on all vehicles.
Short answer: The cables that I bought worked perfectly. I didn't even need the adjusters.
Long answer: The cables fit really snug and do not touch the rim at all. They are a bit of a bitch to get on and off due to the low clearance of the rear but if you just do it and don't mind getting dirty then they are no problem. I recommend a big rain poncho and knee pads so you can lay in the snow without getting soaked. Also, have a THIN pair of water proof gloves(kinda like the kind used by fish market people or dish washers). It helps if you can feel the cable and it gets cold and wet. Practice once or twice at home so that you don't stand in the snow and getting sprayed by semis as they pass by trying to figure out what you are doing. Read the instructions.
Important reminder: Make sure you clip the left over slack of the loose end to the rest of the setup. If you don't it will spin out and hit the body of your car as you drive. I watched a tard drive off and beat the hell out of his rear.
Driving with the chains was not a big issue. I was able get up to 45 mph on the slush/wet. The cable stayed in place and didn't budge. No slapping or rubbing. Clearance was not an issue. In the snow I was doing about 25 - 30 mph and I was in control the whole time.
Obvious but important reminder: Make sure you are in snow mode, it makes a huge difference. I noticed that I was in more control when I let the car downshift for me (auto mode). Manual mode and engine braking made me slide a bit.
Just to make use I don't get a angry PM. I have the X package rims with 255/40 18 and I bought the cables from Shuckes model 1042. Results may vary
