1 - 20 of 59 Posts
Hi Guys,
Here is the history.
Lexus Dealer installed springs (Ltuned) snapped today - WTF!
Installed May 2004
Mileage on springs - 120 K
Eibach has a million mile warranty on these springs.
However I have to go through the dealer that installed these to obtain a Return Goods Authorized number.
I'm guessing that I will be charged labor costs to uninstall and install the replacements. Do you think the dealer will stand behind the Eibach spring warranty and wondering how common this is?
Anyone else have experience here?
Digger08
Reactions: ScarecroW
WHAT?!?!?!!!?!?! :shocked: I can't believe this happened! First time I ever heard of it. Could you take pics?
I may have bad news for you tho. Even if it's the same product... they may have different warranties based on who's name is on the product.
Somebody had a sway bar go bad on them... but since the bars were branded TRD and not Eibach... the warranty was just 2 years. :(
How did you discover this? Hopefully not while you were driving it. :blush:
digger. we'll take care of this.
Thanks Lexusecutive.
Yeah I back out of my garage today....and BANG.
I moved the car in reverse about 15 feet. I knew exactly what it was, looked and sure enough front passenger side spring was snapped.
Too difficult to take a picture, but basically broke on the bottom where it contacts the strut. It is still drivable on the side streets, but definitely not highway.
I still have my stock springs, if emergency dictates I use them. But trying to find another way.
Digger08
WTF? Thats WIERD!!!
Make sure you get your struts checked out! Maybe strut went bad and the spring took all the load.
Quick way to check if leaky strut. Look at the seals and see if its wet. I'm pretty sure you know about this..;) ;)
WTF? Thats WIERD!!!
lol. We both think alike -.-
must be a tech thing :p
but ya. If you see a film on the strut, your okay.
If you see droplets or w/e then you got a bad strut.
If you didnt get the springs from the dealer i would have asked if you got the springs from PACIFIC MALL, hahahahaha
<Crester looks at Digger as he looks at his springs. Digger's jaw drops as he realizes his springs say L-Taned... and not L-Tuned...> :lol:
Wow I never even heard of one breaking unless some ******* heated them up to drop the car more. That would comprimize the HSS and it would snap eventually.The spring itself is designed to take the weight of the car and the strut is there to help slow the rebound of the spring when you hit bumps and stuff.
I hope they cover it,keep us posted.
Try to get them to cover a new strut or labor too.It can't hurt to try:p
Struts are stock Toyota Tokico parts with about 40k on them. I had changed them in 2006.
They are dry with no leaks or evident failure of support.
There really isn't an explanation at this time, except part failure.
Digger08
Here's something random....are your springs rusty??? Do you park your car outside in the winter all the time? or do you drive the IS like a F1 car? haha
Reactions: Johnnysks
Discussion Starter · #13 ·
Spring are not rusty. If fact when it broke, it snapped the paint/ plastic coating off at the break point.
Springs should handle temperate climate changes in North America.
I suppose they do have a usable life, life any mechanical component.
I would assume with a Million Mile warranty, they would last more than 4 years and 120 K.
Digger08
Well, I'm just glad that everyone's safe and that it didn't do damage to other components. :)
Discussion Starter · #16 · (Edited)
ProKit
Update: The distributor is going to replace the coil under warranty
With thanks to some members on here for assistance!
You know who you are.
Digger08
I'm glad is going to work out digger!
Hey Digger, sorry to hear about your misfortune... but also glad that you will get it resolved w/o problems. :)
And you're right, springs should last longer than that, no matter the weather.
How come there's so much rust on the bottom coil of the spring? When I took off my stock springs after 7 years of use... they were still black!
Discussion Starter · #20 ·
Like i stated before, when the spring let go, the paint broke off as well.
It does appear that it has been exposed to the elements for a while. But having said that, you owner's should really get under your vehicle and look the welds and seams on your undercarriage. You will see lots of rust, that is inherent, and can not be avoided. Anything exposed to the water and salt will begin to decomp.
...besides, its not like I have control over this type of thing. Guess I will have to start waxing my springs.
Don't forget, my car has over 220,000 km's now and is 7 years old.
Digger08
1 - 20 of 59 Posts
