1 - 13 of 13 Posts
not sure what section this should be.. but i'm shooting for here anyhow..
i've seen it, you've seen it, you've done, i can't do it!!
how do you spin and smoke your tires while you keep your car still....
anyone know how???? please. :) i want to impress my girlfriend!!!!! ;)
- hahahaha, are you serious???
- anyways, rev the car, pop the clutch, hold brake down
Rev to around 4-5k, drop the clutch, tires spin, tap brake pedal hard,
press gas pedal hard till redline, tap brake pedal hard, press gas pedal
hard till redline.......
I think thats how ya do it...
Any girlfriend that is impressed by smoking tires is high class. :-?
First, get the tires spinning. With a manual transmission, dumping the clutch at high engine speed is rather easy to do. But, obviosuly the car will want to start moving forward. So, use your left foot on the brake, but only to modulate it enough to keep the car from moving. Remember, you are applying the brake on purpose to the spinning rear tires. You can wear out those pads very quicky. But, if you are doing smokey burn outs, who cares about pad when you are wasting $400 worth of tires? Anyway, just keep enough pressure on the brake pedal to prevent moving. Keep engine speed in mid-range, 3000-4000rpm. Redline is a not necessary.
Buying flowers will impress your girlfriend much more than spinning tires. :shame:
Drive careful. 8)
mrwhite89 said:
Take you TRAC off. :wink:
If that don't work, then buy a turb0 :D
That will not work. :shame:
..spinning tires...focking morons..what are you 16 years old....woo-hoo, typical punk ass, you deserve to pay high insurance rates :lol: :lol:
1 - 13 of 13 Posts
