1 - 20 of 24 Posts
I just got sknk2 coilovers
tryed to put them on myself i put the longer spring in the front shot is in the back. the back is slammed and the front is higher the stock
both is adjusted all the way down. can anyone help. instuction or pics would help.undefined
Virgin Magnet
you got it backwards - short springs in the front - long ones in the rear
i did some for a freind, you did something wrong in the front or you have wrong springs for the front. back all the way down should be slammed to the ground so that seems right..
oh and buy the way skunk2 coilovers SUCK NUTS with stock shocks.......the lower you drop it the worse the ride and your stocks will blow out....the lower the faster they will blow out.
Discussion Starter #14
Yea I Drove On It. Nothing Happed
Dont Have Any Pics Yet Just Installed It Today The Ride Wasnt To Bad Beside The Frontalot Higher Then The Back And This Is Killin Me.
Any Othe Suggestions.
you didnt have to pry off the disc on the shock? because on the ones i did the sleeve to the coilovers wouldnt slide on without prying off that disc...skun2 support even told me to pry that shit off.
1 - 20 of 24 Posts
