Thanks to all for your help.There is no need to turn. Just push down. You will feel that the button is spring loaded.
Must be a problem on your end? This is the first time I've heard of a problem with joining. If you still have an issue we may need to contact an administrator.Maybe you can also help with signing in to the forum. When i sign in, using my registered ID and PW it keeps rejecting my sign in. This is a confusing site.
I finally can sign in when clicking on the welcome mail i got when registering,but not the forum site (club lexus)
Thanks
That member. Probably did not realize. You asked in the wrong years. You should post in the right years section. To get a correct answer to your year.NO THERE IS NOT ONE - IT IS SHIFTER THAT POPS BACK IN PLACE AFTER YOU SHIFT.
Also, I'm the only person on here with a CT200h. Might want to try the right forum lol (since I don't know the answer to your issue).i have 2013 Lexus ct200h with no key how do I get it into neutral.
