1 - 20 of 30 Posts
When waiting at a long stoplight, do you shift to neutral? I've heard this type of shifting is common in Japan. Would this have any long-term effects on the transmission? Does your car idle at a higher or lower rpm? Just wondering as this is the first automatic I've ever owned.
whaddya mean... when you are at a red light, put it in neutral and it won't go forward. If you don't, you are braking. Make sure you are on a flat road, otherwise you will roll back. Whats wrong with that?
yougujuhere, what's the point in leaving it in neutral? i mean are some people that lazy that they can't hold down the brake pedal?? gimme a break...half the people i see doing that are wannabe ricers who like to feel like they've got a manual
1997 5-speed Alpine White M3 Coupe
I notice that when I do this, the rpms change fairly significantly. In neutral when idleing (is that a word?) the engine seems to rum smoother. But does this practice harm the transmission?
Ummmmmm......Well, it's call automatic, but I think it's still not fully automatic......You still need to shift it to D to drive......
If you don't shift to anything, your car would never leave your garage......
Um...usually when I drive I don't. But my dad will be getting the Ferrari 360 Modena delivered in about a week, and the salesguy told us that when your at a long stop light, the transmission will shift to neutral itself, and when you need to go again, it'll shift back to first gear. And this is a F1 transmission. so i dunno. Im pretty sure it causes NO HARM to the transmission but if you don't change it, won't it ware down the break pads since your car wants to inch forward??
Spectra Blue IS300
NICE!- Ferrari 360 Modena
lilaznboi, the ferarri tranny is a clutchless manual from how it sounds. its not really an automatic but its not really a stickshift either, its kind o fa combination, but you don't lose power from it, the clutch is operated with hydraulics.
i assume that pressing the brake at a stop isn't going to hurt much, everyone does it. i'd rather hit the brake and have power when i need it than have to shift from 'N' to 'D'
Leave it in any of the driven gears and the torque converter spins ATF. Kinetic energy is dispersed as heat, so:
1. Your tranny runs hotter. Seal and ATF life are both shortened, but most likely insignificantly.
2. Spinning ATF places a load on your engine. Gas is wasted to overcome that load.
If you hold the brake pedal down *just so* to keep the car from creeping, you're also producing a torque effect that jacks up the rear of the car slightly, to no particular good or harm.
There's not enough of an advantage to shifting to N at a stoplight to warrant changing one's driving routine. But the advantage is there, so some do it.
[From TEG: Thanks DtEW - well said! ]
[This message has been edited by TEG (edited October 26, 2000).]
I read in an auto column that holding a manual in gear with the clutch depressed causes unnecessary wear. It made a lot of sense, but I would have to reread to be able to explain it better. Are you sure this isnt the practice you had in mind?
1 - 20 of 30 Posts
