This is a myth to me, but does the centre console in the middle light up? Because I could have swore I saw it once or twice, but sometimes it doesn't. By light up I mean from Park-to-Low. What do you suggest the problem could be?
They all stay lit up buddy and when you shift into gear or park the only thing moving is in the cluster gauge letting you know what gear you are on.
Loose connection? Take it to the dealer if you're still under warranty.
If you're still under 50k miles then you considering you are in the 2gen forum I'm assuming it's an 06 or newer, regardless of it being pre owned or not the warranty still applies.
