ok, I've done some searching and found the wiring diagram for the install but then saw some initial settings to set up the SAFC for our cars. BUT, i would like to confirm the initial settings. Also, after you install it, does the SAFC resets itself from previous settings? I just want to use this as an Informational device and will probly tune it when i get a chance. If theres already another thread regarding this that I have missed, please redirect me in the correct direction.
Thanks
Thanks
i remember i had to change the "knock" to like 5... or was it 10...
it was in one of the threads
This was a setting i saw on one of the thread and don't know if this is correct or not.
Originally Posted by OZIS200
Sensor type: Hotwire
Sensor number: 4 in 4 out
Sensor calibration: 1 in 1 out
Cylinders: 6
Throttle Sensor type: arrow pointing up and to the right
Cylinders: 6
i thats what i was using... let me go run down to my car brb
Cylinders: 6
for the hotwire it reads 15/15
sensor number 1/1
" " calibration 1/1
i read somewhere if your car doesn't turn on the first time. you need to change the hotwire to 15
Reactions: nless_dream
