1 - 20 of 40 Posts
A friend of mine told me that RWD is better than FWD in rain, after he watched Top Gear FWD vs RWD vs AWD show. He said it is law of physics that RWD is better than FWD in rain/wet. any inputs?
I know RWD is better than FWD in dry, but not sure in rain. any inputs?
- FWD all the way....
The problem I have with FWD is that once you break loose the front wheels, you have no steering control. With RWD you can use both the steering and the throttle to control direction.
- I think it would be a fact that FWD is more "stable" (whatever the word im trying to use) than a RWD vehicle...
yup. especially on curvy, snowy mountain roads in the winter... coming home from a day of snowboarding......
I've always been able to handle my FWD in the rain, as if it was dry weather.
this thread is like asking if you want a chic with a BIG AZH or BIG BOOBS.
sometimes you can only have one or the other.
if you want both then awd is highly recommened! :eek:
for me, i take ANYTHING :p
- big ass and big boobs can be found here in san diego... called a MEXICAN :crazy:
:eek: :eek:
:lol: .... mostly in your neighborhood dut.
man last time i was in cali was a year or so ago
yeah dose me-i-canas got B52's up front, and dat bull ride strap in the BACK :lol:
it just those hairy arms that can freak me out sometimes :lol:
up in hawaii, nuttin but asian ho' and those waikiki hookers :eek:
try driven you lexus by them, dose hoe's be runnin up to your ride and asking you that famous question,"
WANT A DATE? :D
just thought is share with all
-peace
- yea, but I like asians only.. hahahaha
- asian hookers??? send me one :crazy:
Well if your racing and a race car driver, then rwd might still give you better handling....
But for normal street driving, I would say FWD is safer for the average person.
When your front wheels slip, you usually have an understeer situation.
When your rear wheels slip, you usually have oversteer.
And generally, understeer is considered "safer" than oversteer.
I think it's more tire dependent than drive wheel dependent. My bmw is a lot better in the rain than my GSR was, but I think it's the tires. A skilled driver is probably faster in the rain in rwd.
In my accident reconstruction class, we did calculations that showed that front drive cars are actually more stable in that they tend to resist rotational moments - the front wheels actually pull the car back into the straight ahead direction. Rear wheels act to push the car in the direction of the spin. But all these effects are easily overwhelmed by the throttle inputs of a bad driver. :wink:
Each has its advantages as well as disadvantages.
The tires can only provide so much traction, which is especially important in wet conditions.
In FWD, front tires steer, as well as drive, as well as carry most of the weight on them.
In RWD, front wheels steer, rear drive, weight is distributed close to evenly.
Generally, FWD is safer because it does not require as much experience to handle than RWD. Understeering from FWD is easier to control than RWD's oversteering from experience perspective.
Weight shifting also plays a big role. When accelerating - weight shifts to the rear wheels, when braking - to the front. In RWD, slight engine braking during a turn would create more weight transfer to the front, creating a better grip (do not do this with e-shift).
I would also like to throw in the fact that Manual Transmission allows better ability to control oversteer or understeer. There are 2 reasons:
1) When wheels loose traction, they spin at the constant speed, rather than accelerating.
2) Clutch can be used to disengage engine input to avoid acceleration or engine braking to provide neutral handling.
1 - 20 of 40 Posts
