yes im stubborn and pushed the tire size just a little, im running the 19x8 moda r6 with 45 offset, i ran 235/35/19 all the way around, with an h&r drop, i rub a little in the rear but i know how to fix that it is the front im worried about, ive already heated the inner fends and molded themnow its just the top that is rubbing on bumps and turns. i have 2 ideas how to fix it but there maybe other ways i have not though of so your ideas would be greatly appreciated.
Option 1
take it to the alignmnet shop and get him to throw some negative camber into the mix, im not really worried with tire wear b/c ive had my car for a year and 2 months and only put 2k miles on it, so im not worried with tire wear, they will dry rot before they wear out.
Option 2
take the top part of the inner fender out(plastic liner) and grind the top 3/4 of the fender where the tire rubs
which would you do or recomend if this was yours?
Option 1
Option 2
