1 - 12 of 12 Posts
Does anyone know if the RS200 dash will work for IS300? I'm assuming there is some modifying to do... but has anyone try or make it work?
Threadlocker
getting the wiring right could be nearly impossible. someone on here was trying to wire up his jdm altezza dash unit a while back...
it would be so cool if the RPM meter is in the middle..... :-?
Discussion Starter #7
Yea that's what i thought... also it would be easier when you are on track to see the RPM meter... :wink:
i have the jdm dash in my 03. it pluged right in and worked. i did not have to rewire anything, i just lost the dimming , mpg, and the abs light is on.
You lost the dimming on yours? Mine dims just fine. I also unplugged the ABS bulb so the light isn't always on.
I would rather pick up the RS200 cluster too, so if anybody can get a hold of it, let me know. It should plug right in as 13s_is300 said above, but you will lost the MPG and gain a non-working fuel pressure gauge. However, there are some people that have run an additional line and made it work just fine. I just haven't gotten around to doing it yet. I'll wait until I get my new cluster.
I wouldnt mind getting one of these to try and work on. Regardless of te difficulty level, I am sure that any of the JDM Altezza stuff can be re-wired to work with the US spec IS. Has anyone tried to do this?
Chris
Discussion Starter #11
What does the JDM dash look like? It's not the same as the RS200 dash rite?
Does it have the RPM meter in the middle?
does it?? :eek:
1 - 12 of 12 Posts
