Problem: Rough idle
When: It happens when the Air Con. is off. When I turn the Air con. on, the idle is good
A/F ratio: With A/C off high 10s to mid 11s
With A/C on mid 11s to low 12s and sometime up to 14.7 The A/F ratio changes all the time from 11s to 14.7 when idle and light throttle, but A/F perfect underboost.
Have any of you guys had this problem before? I've tried changing Haltech setting from Batch 1 to 3, but didn't do much. Could this be a problem from installtion? Thanks for all the info.
Discussion Starter #2
I see that Toyomoto includes MSD IGNITION DIGITAL DIS-4 with the Haltech. Would the rough idle condition be better with this unit? Now sure if it'll solve my problem.
Thanks JAman and Maxxpsi. I'll try both.
Did you get it to work? What was the problem?
Discussion Starter #7
I've changed back to my previous setup now (emanage with TE conditioner). I've had too much problem with haltech eversince I used it. There was nothing wrong with haltech, and I have good tuners around here, but they've just never experienced tunning standalone IS. With emanage setup at least i know it works because I've used it before and run no problem.
