1 - 2 of 2 Posts
Ive been doing some research and this is what I came up with for the rim I wanted to purchase. I need your inputs if I can do it without mods.
Size 19:
Front : 19x8 w/offset +40
Rear : 19x8.5 w/offset +43
Tire Size all around: 225/35/19
Size 18:
Front : 18x8 w/offset +43 or +44
Rear : 18x9 w/offset +43 or +44 or +49
Tire Size all around: unknown...suggestion?
I really want to get the sets of 19's... but if not possible with those size/offset I need your input on the size 18 which offset will be the best for the 2002 is300
Now am I gonna have a rubbing problem in FRONT/BACK?
How much drop can I go with this (I like how the tire goes inside the fender)?
the 19s fit but a bit higher offset would be better (you might need a roll so you don't rub)... i like the 18s set-up though cause with a +49 offset you might be able to pull off a 255/265 tire with just the same minor mod :approve:
1 - 2 of 2 Posts
