I'm lookin to get some new rims at 18x7.5 but the particular wheel comes w/ an offset of 35 or 45. If yall could be so kind and give me your thoughts on which is a better pick I would appreciate it. And yeah i know i could search the forum but I'd rather just post it.
JCH
Usually for that size a 42 offset is recommended. I think 35 might stick out if not rub, If it is just between 45 and 35 I 'd go with the 45 offset because ur stock offset is 50. THe stock wheel size is 17x7.
i have 8.5 inch rims in front with a 45 offset. doesnt stick out, doesnt rub whatsoever. hope thats a little bit of help
To jchthe3rd I just did some research and the 35 might work not 100 percent sure but I 'd go with the 45 offset. Like mikefate I used to have 8.5 in the front with a 44 offset and a 9.5 in the rear with a 45 offset. Now I have 19x7.5 with a 42 offset in the front and 19x9 in the rear with a 50 offset and I have no rubbing issues and wheels sit flush as before the wheels I had sat a little out. Hope this helps you n let me know.
