Retrieving Codes From 2jzgte vvti. I completed a 2jzgte vvti swap in my SC300. The check engine light illuminates any time I go from Vacuum to Boost. My OBDll Scanner is unable to retrieve the Code or codes. My question is how do you retrieve the codes from your IS300 with a 2jzgte vvti swap??? Is there a special Scan Tool needed for the 2jzgte vvti???
Just for others that might need to Retrieving Check engine Codes From 2jzgte vvti Swap
Bridge Tc and E1 With a Piece of Wire Using the Diagnostic Port in the Engine Bay.
