right that would be a staged nitrous setup. without a staged nitrous setup...you have no choice...there is no luxury of running stock timing. you would need something like this...there is a cheaper NOS staging gizmo around 215-250 bucks that will let you do this...its just a simpler box.
http://store.summitracing.com/egnsearch.asp?N=400228+310644&autoview=sku
but for anyone just throwing on a nitrous kit and setting the jets to do a 125 shot....you got no choice but to retard the timing 4 degrees...which in turn will get you to run like you have an old muscle car...when i fact you have a nice lexus. we ran a 50 shot on my brothers jetta and we got away with 4 degrees of advanced timing. he was running a chip in his car...
well nitrous comes in at 1000psi and turbos do what...on super cars 50psi...that still nothing in terms of psi.
so yeah nitrous is very differnt then boost from a turbo.
When you heat nitrous oxide to about 570 degrees F, it splits into oxygen and nitrogen. So the injection of nitrous oxide into an engine means that more oxygen is available during combustion. Because you have more oxygen, you can also inject more fuel, allowing the same engine to produce more power. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder.
when your talking turbos....your talking about moving air volume. Turbochargers allow an engine to burn more fuel and air by packing more into the existing cylinders. and that packing of air from a turbo causes a lot of stress on the internals....go ahead to try to run even 20psi or 12psi on your stock internals and lemme know how it goes. this is why people swap their internals...we are talking to completely different animals...where boost is not just boost.
