1 - 15 of 15 Posts
i just got my 05 is300 few months ago, and i've reading this forum for a month now. i read some of the post discusting bout reseting ECU? CEL? or whatever. some users say, it's good to reset the ECU when u have engine performance parts installed i.e. CAI, Headers, Racepipe, and Exhaust.
How is it actually done?
What is the advantage to it?
disconnect the neg terminal to the battery and push on the brake 10 times...that will clear the ecu, basically starting fresh
push on the brake 10 times huh~ :suspiciou hmm.....
will i see or hear a signal if i'd done correctly that step?!?
yes a bright light comes from the heavens and an angel tells you you've have correctly reset your ECU.
Pull your efi fuse under the hood wait like 1 min and put it back in should reset it. Then you don't have to reset your clock and reinitialize your sunroof.
Discussion Starter #7
........ :suspiciou
Discussion Starter #9
sweet! okay. :cool:
:lol: when i reseted my ecu i saw the light and thats when i knew i did it correctly...
hirenjani said:
hey i've been wanting to rest my ECU....(my car has been a little slow lately)and i clicked on the like didnt work...
ehhh I never push it 10 times.. more like 3..
i heard there was a reset button on all ecu. is that true?
Just pull the fuse so you don't have to mess with disconnecting the neg battery terminal.
1 - 15 of 15 Posts
