1 - 8 of 8 Posts
Anyone try both of them?
I wanna change my tranny oil... which do you guys recommend? :-?
Thanks in advance
I am currently using the Redline MT90. I think I will be switching over to probably Motul 300V or Neo synthetic when I hit 10k or so. The MT90 is not as smooth (shifting-wise) as I had envisioned.
The Redline MT90 is around $9/qt. Neo or Motul will run you approx $11/qt.
So answer you question, I would say Motul, then Neo.
My 2 cents.
Thanks for you guy's imput...
What do you think about the Redline?
Makes the shifting better? Smoother?
It doesn't seem to have had much of an effect on my IS. A bit easier into 1st and 2nd but not much. On my s2k it has seemed to make a much bigger difference. I'm gonna use it in the future but don't expect anything dramatic in the IS tranny.
1 - 8 of 8 Posts
