1 - 8 of 8 Posts
I've got the mazzuri headers and y-pipe and now i decided i wanna get a hi flo cat just to get rid of the smell and everything. dont really know anything about these so i was trying to see what kind everyone recommends. also a good cheap place to buy it from to. and i was just wondering where i should weld it in. ive seen people do it in the y-pipe but i dont know if i should closer to the headers or closer to the b-pipe or just in the middle
there are a lot of threads talking about this exact thing
anyway, i have the magnaflow spun cat welded to the y-pipe, just before the flange.
but if you search for those threads you'll find all the info you'll need. i went into a lot more detail in a couple of them as to what i did
After doing some research ive decided doing the same setup as bbatl6 with the mangnaflow spun cat welded into the end of the y pipe. Hey bbatl6, did you use model #59956 which is 2.5" and I believe 8" in length?
i have that setup too^^ thats exactly right, i believe its 9in instead of 8in
Reactions: SexusinmyLexus
i actually don't know it's length, but it fits perfectly in the bent section of the y-pipe just before the flange. but i did use #59956, which is 2.5". if you are going to try to fit it in the b-pipe (which i am not too sure about the fitment), you will need to get a different model number because the diameter is 2.25" and not 2.5"
IMO Random Tech makes the best high flow cats.
EDIT ooooohhhhhhh evil post 666!
1 - 8 of 8 Posts
