Hello all, i just found out that my passenger side rear speaker isn't working, no sound at all, i dont know when did it stop working, or was never working,
how can i check to see whether its the speaker wires problem, or the speaker is dead.
really dont want to change the speaker, but if i do, what speakers are good??
btw, I got Kenwood 8403 4 channel amplifier, with that amplifier, what speakers are good with that setup.
This is for 2002 IS300, I have Kenwood DNX7100 HU, amplifier not install yet.
im looking at the
CADENCE CVSL69 6x9" 3 WAY SPEAKERS WITH 300 WATTS TOTAL RMS, 2" VOICE COILS, 70 OZ MAGNETS, AND 3 WAY EXTERNAL CROSSOVERS
and
BOSTON SL95 6x9 200 WATT SPEAKERS
anyone experience with those?
cadence seem pretty good
Yikes! You were running the stock rears with the DNX7100? The stock rear's are actually 2 speakers in one. The tweeter ran on 4 ohms, and the woofer ran on 2 ohms. Were you using the Metra harness?
ya, i have stock rears with DNX7100, did it in circuitcity, no amp, i dont think he using the metra harness, i have to check the wires and see wuts the problem with my passenger rear.
Am i able to use the Kenwood 8403 AMP unit with stock speakers?
Im thinking of going change my rears, to either 1 of the 2 list above.
If you've been running the stock rears off your headunit there is a better chance you blew that channel of it's internal amp rather than blew the speaker I would think.
I have Kenwood KAC-8403
4-channel amplifier
60 watts RMS x 4 at 4 ohms (90 watts x 4 at 2 ohms)
180 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
front channel high-pass filters (50-200 Hz at 12 dB per octave), rear channel high- and low-pass filters (50-200 Hz with 12 dB/octave high-pass and 18 dB/octave low pass)
bass boost (6 dB at 90 Hz), channels 3 and 4
Tri-way capable (Tri-Way Crossover required)
preamp- and speaker-level inputs
fuse rating: 40A x 1
p.s. yeah, i must have gave everyone non positive repz that night, i go click click click, and then one member ask y i gave him negative...
