1 - 2 of 2 Posts
After refreshing the majority of my car with superpro bushings the only spot left is the rear upper control arms. I was unable to reach these without having to remove the rear subframe. My main question is where can I get rear upper ball joints. I can't seem to find them on the internet. Are they the same as the front ball joints?
You can. The last time I looked. Just the joint was too much. You can get the aluminum GS300 upper in a pair for about $180.. They bolt up the same. The bushings are different from the IS300 upper bushings.
1 - 2 of 2 Posts
