Uhh.. im getting annoyed with the rattles im getting from my system...i fixed a lot of it but now my gas lid is rattiling what did yoou guys do to fix this problem?
I recommend this common question (with it's answer) be made/put into a sticky.
when a lid rattles at my shop sometimes (depending on the car and other factors) we take a little double sided tape and apply a piece or two to the inside of the lid and then put a little thin rubber on the tape to give it some padding from where its hitting. good luck.
I did dynamat and it solved that problem....at first it was really bad though...i experienced the same problem....
