1 - 10 of 10 Posts
Hi,
Couple days ago I felt lost in power and heard my valves knocking. Today when I started my car (2001 IS300 200000Km) I was feeling that engine was vibrating, it feels like one or more cylinders are not working. I tried to read codes with obd computer and it gave me code saying random misfire. I did check my spark plugs, wires , coils and compression. Everything looks fine, last year I changed spark plugs, wires, and coils. What else it possibly can be? My local mechanic said that it might be cheaper to replace the engine then to find the problem...
Is there anyway to check injectors than replace them??
Disconnected vaccum tubes will not cause p0300s. Anyway to have inejectors check is one to make sure you are getting a signal at the injector harness with a noid light. And secondly you take it to a shop that can flow/bench test the injectors.
BUN
but i disagree, one day after using sea foam through my vacuum tube my cel came on, so i drove to autozone and got a obd reading. i got about 4 p0xxx codes(misfires) and the autozone dude looked it up, one of the reasons was insecure vacuum tube. So i snuggly refit my tube and reset the ecu and everything was good again
A mutiple amount of codes can lead you to diagnose a problem that isn't originally related to the codes you get from the scanner. A cingular code leads you straight to the problem, ecxept in obd1 cases.
BUN
Are you losing any coolant? Have you overheated the car recently? Absolutely check the injectors but it's also possible a bad head gasket could allow coolant into the combustion chambers and cause mis-fires too. I've seen that happen for sure.
I would disagree with your mechanic that it's cheaper to replace the engine than it is to fix the problem. Even if it was a blown head gastket I bet it would be cheaper to replace the gasket than the engine. Sure it's a REAL PITA... but so is pulling all the accessories off and the engine out.
number of things to consider : spark plugs wires - do a compression test or a leak down test; too little fuel can also cause misfire; check also the head gasket.
A friend of mine had that problem before, it was because of its spark plug wires and a broken head gasket.
I hope you'll able to find/solve it soon. Its quite expensive when car is having trouble just like what happened to my car a weeks ago, I have to replace some of the auto body parts and wait for a couple of days before I can get my car and use it. *sighs*
I think one of your coil pack is not work properly, i had a misfire once. I just had to replaced the coil pack, problem was solved.
1 - 10 of 10 Posts
