well after attempting to reassemble the bottom part of the intake manifold and installing the fuel rail, you guys know the two washers that go on the top and the bottom of the fuel line? I lost one of the washers and i doubt the is a part number for it and hardware store dont have so im screwed. It looks like this..
Let me see if i can find you a part number, hold on.
No part number according to my source however measure the inside diameter and go to an Ace Hardware as they have copper crush washer.
What you have there is called a Crush Washer.
I believe what you have there is a 10mm crush washer or a 3/8. You can get them online just do a google search.
ok wat is the name of the part that is on the fuel rail that is screwed on through the fuel line?
Auto zone has a selection of copper washers for unions, they are in the draws of misc pieces, take yours with you to get one the same.
