1 - 11 of 11 Posts
I hope somebody can help me out. My power mirrors and radio just dies on me. I checked the minis with a continuity tester and looked at the larger fuses. Everything seems to be OK. I even tried resetting the ECU. I looked at the power wired for the mirror tilt, but I didn't see any damaged wiring. I still have to remove the HU, and look at the power wires. AFAIK, everything else seems to be working.
This happened while I was setting my Token mirror tilt. The mirror stopped moving, and the radio (AVIC Z1) shut off. Maybe I possibly missed a fuse, but I checked the Radio 1&2 fuses at least 3x. Has this happened to anyone else? I'd appreciate all the help I can get. Thanks!
Edit: no power to climate control either.
sucks to hear Rey, but u wired everything urself so it should be easy for u to diagnose...
Discussion Starter · #3 · (Edited)
I was in a hurry to get it fixed because I had to pick up my son, and I got a little sloppy while checking it out. I swear I checked the Radio fuse in the driver's kick panel multiple times, and got the green light from the fuse tester. When I pulled it, and looked at it, I could see that the fuse was just barely gone. I took one of my spares, popped it in, and now everything is back to normal.
Recap: Radio fuse (10A) in driver's kick panel = no power to Radio, P/Mirrors, clock, temperature display, and ignition key light.
nice.
sometimes fuses pop and you will have good continuity and a green light and 12 volts on both sides. but when it is inspected its just barely cracked and touching just wont allow that much current to turn on the parts..
Had to Raise this from the dead
Bless you sir! You saved me hours upon hours here.
I had my Oil Press, Wideband, Boost gauge, not to mention some of my audio tapped from this exact location.
I had a fuse block extension, with a 10 amp fuse that was good in place. After searching around tonight for "Power Mirrors, temp display, clock, Radio not working" i found this. I pulled the fuse block extension and just dropped back in the same 10 amp fuse and everything was working.
I will have to pull power to my gauges from another location for sure. In my case the fuse was not bad or sorta bad I was just asking to much from the Radio 2 location on the driver side.
djspock3030, I'm glad you figured it out.
valhallab, The TS mirror tilt is a really nice item. It basically works as an up/down timer, so you can adjust it to your needs. I've had it installed for a while with no real issues. I think I've blown the included 2A fuse once or twice in a couple years, but that's it.
Correct.
Reactions: valhallab
Did you get the single unit or the deluxe (double-for both mirrors)? If you got both, how hard is it to set the two timers to the same time? Did you notice the min or max time? I might be able to pin em to get them equal.
1 - 11 of 11 Posts
