so I brought a 1987 r154 just been rebuilt am going turbo so I needed a stronger tranny... now my question is do I need the speed sensor cable,can I use the r154 flywheel.and can I use the r154 driveshaft.... what clutch is good but not to expencive... and what's the 411 on the sc300 shifter is it the best that's there so we won't run into problems as far as when u shift u won't bang into n e thing... my car wil be 450 + to the wheels..can someone please give me a run down of what I need please....keep in mind it's from a Toyota supra.
I used no speedo gear. You need either a custom driveshaft, or the driveshaft shop driveshaft for the r154 in an IS300. I also use the factory mkIII supra shifter, the shifter hole has to be cut some, but it will fit perfectly out the shift boot. You can pm me if you have any other questions.
