Any opinions on Diamond Audio D6 amps?
Specifically a D61000.1 to run an idmax12 @ 1ohm
and the D6300.4 to power Hex S600s front components and Hex S6.0mx3 rears
For the hex, what's the difference between aluminum and silk tweeters?
D9's are nice, but too expensive. I plan on bridging the channels to produce [email protected] to the front speakers and using the raf technology to hook up the rears.
What do you guys think?
Useless
The D6 amp will drive a ID Max just fine. The new D6 amps really are a nice product as well as having loads of features and a little under rated to boot.
The setup should work just fine. If you are not doing an AV system, then I say get a 2 channel and use the RAF feature of the component set.
The Silk are not near as bright or harsh as the Aluminum. Its a personal preference thing as well as music taste. If you are hard core techno, trance, rap the alums will help keep it in perpective to mass bass. The silk are my choice though.
