1 - 11 of 11 Posts
Just curious, I read some threads back from 2005. Someone here said the manual stock spring rate and height are different to those of e-shift. Is that real? What are the differences? Same shocks different springs?
BTW, I'm new here. Greets to all IS300 owners.:)
yeah i heard the same thing here.... not quite sure on the answer tho! :suspiciou
Threadlocker
actually it was more of a 01/02 vs 03+ type of discussion before i believe.
not sure if there's any truth to that rumor.
i heard the 01s stock were lower than all the other years.. and they raised it after the first year of production or something. not sure -_-
yes 01 was the lowest one. 01 FTW
Domestic Reaper
I did the "scour"ing for you.
-Overall height raised 0.6" (from 54.9" in 2001 to 55.5")
-Minimum running ground clearance increased from 4.9" for 2001 to 5.3"
-Spring rate increased for 5-speed manual
http://my.is/forums/f52/2001-2005-is300-definitive-changes-list-228212/
Your welcome :)
this deserves some reppage. I was curious about it too. Funny how a guy with less than 50 posts knows how to use the search function better than alot of ppl on this site. Oh well. Rep when i can because im out for 24.
Your welcome :)
nice... thanks a lot
i wonder if Lexus made change to the spring's length or the shocks.. anyone know about this? cuz I want to have spring replacement and I have a 01. If the shocks of 01 is shorter than 02+, then my car will drop more than I thought.
Thank you so much... !!:)
1 - 11 of 11 Posts
