You can't. Live with it. The computer is sensing no return back to the input because you just cut off the two circuit of the airbags.
Two things you can do, from what i have heard....
Ps i have stripped is300 and no light on the dash at all......
Trace back the wire and remove it from the source then there should be no light or remove the fuse, not sure whatelse you will lose.
David
I don't have Sparcos, but I do have Cobra seats in mine (better IMO). I just removed the light in the guage cluster. Not sure if removing those side impact airbags incompletes the circuit or not. In case of an accident, I don't know if the airbags will deploy or not. I don't want to test it either.
