Hey everyone,
My 05 ggp IS isn't playing any of the burned cd's that I've been playing, sometimes even with factory CD's that i've bought from stores.
when i try to play the cd, it would say "ERROR" and i'm wondering if anyone else here is experiencing this. if i get lucky, the cd would play, but most of the time, it would display "ERROR" whether it's a burned cd or a factory cd.
when i take the cd and put it in my parents RX350, it works fine.
my next problem is with my front and rear wind-shields. they tend to fog up easily and they do not defrost unless i put it on 65degrees and on high.
can anyone help me out on this?
Your cd unit should be covered under your basic warranty, unless you're over 50,000 miles.
Automatic operation: If you set your air intake to outside air, airflow to floor. For faster heating , select recirculated air for a few minutes, to keep the windows from fogging, select outside air after the interior has been warmed. Then push the A/C button on for dehumidified heating. Choose floor /windshield air flow to heat the vehicleinterior while defrosting or defogging the windshield.
Reactions: kraze8
