1 - 2 of 2 Posts
Im going to keep this short but Ill give you all a good idea of what is going on. First my question is, what RPMs shoudl I set my window switch to spray nitrous on a 5spd? I was using 3k-6k but I think I should widen the window a bit?
Anyhow went to the track. Venom VCN-1000 running a black nozzle (either 80 or 100 shot im not sure) SRT intake w/ R-ECU, HKS Hiper, stock rims, no spare (nitrous bottle is in its place). Im not giving exact numbers until 1) my headers and midpipe are installed 2) i run without bald rear tires (shitty 60 foot times) and 3) I figure out exactly the window I can spray the nitrous in... BUT i will tell you i was well into the 13s and have expectations for a very low 13 second pass.
Am I Hype-R???
i would keep the window you have...unless you want to raise the upper limit to just under redline...or just under where the car would hit the rev limiter...
1 - 2 of 2 Posts
